All apps are still there. My flash player doesn't seem to be working in Chrome; looking into it though.
So do any backups you want; do the backup within ClockWork.
Then go to Advanced in Clockwork; clear the dalvik cache.
Then backup and clear the partition cache.
Then install the new ROM.
Confirm the build version after reboot is Aug 7th.
EDIT: Flash is working. Not sure what it was, if anything. I did reinstall it over the existing install and did a reboot. Not sure if either of this addressed it, or if it addressed itself.
Chrome doesn't support flash, only the "Android Browser" does... are you sure you're using Chrome?
