I would love to use this ROM as I have heard great things about Pete's ROMs. The fact that NFC doesn't work is what is holding me back![]()
doesn't bother me because i haven't found a single store that accepts NFC payments and don't know anyone else with a GNex.![]()
and all of the 4.0.3 softkey mods are back! it's amazing how well begging works.
[MOD][4.0.3] SOFTKEY MODS WITH 1% - RootzWiki
adding these to the OP as well.
Mcdonalds is what I used....got $10 from google just for using their prepaid card.
I guess I'm lucky, there are a lot of places around me that accepts Wallet. For what it's worth, I have found that it's accepted at almost all CVS, Hess and Sunoco's I've come in contact with
Hi, I just tried to load Pete's 12-22 ROM. I used ROM manager to download and then started the install. Everything seemed to be OK and the Nexus rebooted and now is locked in the flash screen. I have tried removing the battery and when I reboot it goes to the flash screen and stays there. How do I boot into recovery from here? Any help would be appreciated.
SolidOrange. Are you still using Pete's ROM and if so how is battery life for you? Are you using a custom kernel?
Thanks!
Installed this the other day. Seems to be working well, really nothing special but nice and fast. I like stock ICS anyway so don't need any tweaks. The only thing I'd like to see (and I know it's in a couple other ROMs) is a numerical battery level. The one on the The3ry ROM for my Bionic was really slick.
