Try changing zip to apk and install that should work.
As for battery drain it may take a few days to build up cache and for the kernel to "settle"
Worked like a charm, thanks Yeahha!!!
Im a noob!
How did you rename it and install it? HELP please! lol
The way I always do it is to go into recovery and not use RM for flashing roms. I use it for other things like backing up but not flashing full roms. So in recovery I go to mounts and storage and then format system, then format cache, back out go to advanced, wipe dalvik. Then install rom, install the new extras then reboot. Naturally, this is all after you do a full nandroid backup.If im on v1.0 how do i upgrade to 1.1? Just dl the 2 files, go into cwm via rom manager, then wipe data/cache and flash the 1.1 file and then the extras, then reboot?
I hope you updated to 1.1 this morning.
Yep, just disable boot animation in liquid settings. (interface-general)
How can i change the color of the status bar text? I changed it but it didnt change. I want white, not blue
Did you reboot? Did you first hit 'set'?
I was at 30% went i went to sleep and after 6.5 hrs it was at 98%....THAT slowly? lol
