johnnybirdman
14.1 - so far so good. have to admit to having 'less than stellar' battery life with 14.0 (stock kernel) but I couldn't pin down any particular issue/cause. hoping for better with 14.1.
J.
J.
Also, can you all let us know if you are still using this ROM?
When you go to open it, it says it is incompatible. Side loading doesn't change that. So you can never actually open the app. This is different from the warning message at the top of the app which does allow for use of the app.JMar, i don't blame you for that one, it was a deal breaker for me on the Nexus when it wasn't working. Any idea what is broken on wallet and the N4?... I have the most recent apk if you wanted to try to reinstall just wallet. I am currently missing the leankernal i like, but sure it will be available soon.
Otherwise, I am not seeing any glaring issues..
) suff. But whats up with expanded desktop? Is it not available yet on 4.3? Because its still showing up as an option in JDX settings to enable, but im not finding out how to get it to actually work.I just installed JDX v15. Hadn't updated for a while so I'm really enjoying the update. I noticed that neither my network indicator nor my WiFi indicator turn blue when data is running through. In previous versions it would start off grey but turn blue when it connected to the web. Not sure if something is wrong or if this is just aesthetics. If the latter, am I able to change it so that its blue? Lol, I know, this isn't very important. Thanks for the help tho!
