Ok, so I was installing v13.1 of JDX. Here's what I did: rebooted into recovery, wiped cache (and Dalvik, just for good measure). Flashed JDX v13.1 ROM and then flashed the GApps file.
YouTube is missing, so I looked it up on the Play Store and hit install, but when it's done downloading and goes into the "installing" it says "incompatible update". And I can't install YouTube... how can I fix this? I really would like to avoid having to wipe data and flash the whole thing... any suggestions!? Thanks!
This should probably be posted/moved to the JDX thread (Mod?)
To answer your question, I would make sure you have the 2/14 version of the gapps and reflash at least the gapps (could reflash both if you want after wiping cashe and dalvik again), then run fix permissions after that.. reboot and see what you get.
I just did v13.1 today with the 2/14 gapps (dirty) over v13... so far no problems. hope this helps and let us know if you need more help.
Just wanted to update after my audio Fix install... Back to perfect. Excellent fix... That said, I am not sure why this fix worked, since it just puts the audio code back to 4.1x levels? There must be something bad in the 4.2.2 audio codes that is faulty maybe.. I am sure the Devs will figure it out before VZW..but still. Hopefully the fix will be built in or fixed in the next build!
How is everyone else doing with this ROM? Still using it? Running well?
New GAPPS... Could 13.2 be in testing..? Lol
Can I dirty flash the new GAPPS on top of 13.1 and the old GAPPS or will that cause problems?
YouTube is the only app that I have problems with. I will have to double check if I made a back up when I did this flashing. It was a dirty flash and I don't remember if I did a back up... I know, don't judge me! lol. I didn't think there was gonna be a problem. But I did install the correct files. YouTube just won't install.![]()
13.2 + lean.....wow fast....
