12.2 is coming soon...
12.2 is out.
Edit: Camera has significant lag and gallery is broken for me.
Make sure to reboot to recovery, clear dalvik and fix permissions.
I had both of those happening on a dirty flash, but after a fix permissions it's working again.
Edit: other people are reporting the same thing, with lag in the camera. Jake is recommending to make sure that you clear cache both in the app itself as well as in recovery, as well as making sure you updated Super SU from GPlay.
Good luck!
Ryan, are you running this?
What are your thoughts?
jmar
I just started running 12.4 today and everything that I have tried seems to be working. I'm using LeanK latest version. I'll give it 24 hours before I decide if battery is okay.
The only problem I have had with 12.3 and 12.4 (and maybe prior versions but I didn't notice until now) is that when I try to upload a picture to FB it craps out and tells me FB has crashed/isn't responding. Don't know if the is a 4.2 thing or a FB thing?
Any preliminary impressions on the battery life using Lean? I'm still on the stock kernel and am considering switching back to Lean 5.8.2.
jmar
