You wrote
This keis and odin are only needed if something goes wrong with the kingo method right?
I'm on my 2nd reading of this. downloaded kingo (Kingo_Android_Root_118.exe) I hope.
I saw the link to download the stock rom. There are odin flashable listed and RETAIL ONLY odin flashable. Which do I want?
Next question. once superuser installed. then safestrap is installed. in the video they talked about installed the stock rom image in one of the custom slots. I want root primarily to freeze vzw bloat, and for TBpro. What happens if running stock rom in a different slot. can you accept and OTA?
Where is that installed? on the custom slot? How does hyperdrive accept OTA?
I'll save my hyperdrive questions for another post.
Hi eclipsed and germ... You are welcome PM me... We can set up a Google chat to discuss or even a phone call. I have used kingo on my VZW note 3 about 6 different times, and eventually it works. That said, the important pieces I found were: using a usb2 plug on a desktop with ADB installed including the drivers, and making sure the phone connects with the correct Android driver in the device manager before starting to run kingo. Also, make sure that you are using a clean stock OS slot, factory reset, with the latest baseband installed, no SuperSU, and No safestrap. Everything stock.
It may sound like you could lose everything, but I used my SD card to save my rom files, Odin files, SuperSU and my TIBU files... So I don't lose anything. Then run kingo on a desktop with ADB installed and functioning. Also give kingo a chance and try it a few times once you check all of the above.
Good luck, if you have the retail note it does work eventually, if you have the developer or international version there is a different process.
That's odd. You're on a desktop machine, not a laptop?
I have a Win7 laptop and root failed every time... I don't recall WHERE in the process it failed, but the phone would never root. The Win7 desktop I think took 3 tries, and even then I wasn't sure if it was rooted. Had to verify with Root Checker, which confirmed root access. Then I put it BACK on Kingo and the option appeared to unroot... so it DID finally root.
Good luck!
You need Safestrap FIRST. It's essentially the modified version of TWRP that's designed to work around Knox and the bootloader.
Do your Safestrap bit, make sure that the Stock Slot is your active slot and make a backup of your stock configuration. At that point, it'll be easy to set up Slot 1 and flash Hyperdrive to it at your convenience![]()
