My apologies for the delay to get back to you.
It worked, and thank you!
Now, here are my rooting questions. If you have too then will you create a new thread for my questions by moving my questions out of this thread?
I would like to use TWRP recovery, so here are the steps I would take, so please correct me.
1.) Follow the rooting YouTube video I used to root my S3 the first time, and install the CWM recovery just for now using CWM?
2.) Once rooted, make a backup in the CWM recovery, and how would I do that? BTW, my SD card is still not recognized.
3.) Once the backup and rooting is done, then go into the Play Store, and download GooManager which that will flash TWRP and it will get rid of CWM?
4.) Make a backup using TWRP and use backup compression?
5.) In this order wipe cache, wipe Dalvik cache, and then factory reset?
6.) Flash CM?
7.) Flash gapps?
8.) Would there be anything else?
6.) Flash CM?
7.) Flash gapps?
