legslujack
Hi. I have a generic question. Does anyone know how to scroll through a comment box which for example is used in surveys,
I would like to scroll through my text to make sure that my grammar and punctuation is correct before submitting it. Sometimes the response may be pretty lengthy.
I know you can scroll by the normal swiping of the touch screen method ordinarily; however, this does work well when you have a small box that hides the rest of your text as you are typing a lengthier comment.
Please be as specific as possible if there is a way to do so.
Thank you.
Thank you.
