[Verizon] [solved] high CPU temp due to overclocking?
You can do it as long as you tell me how exactly:)
As the OP (original poster), you should be able to go the "Thread Tools" drop-down just above the first post and then select "Edit Thread" (click "Perform Action") and then update the Title text and click "Save Changes".
This may only be available to you shortly after thread creation, but I'm not sure of that...
I'd like to leave it up but change the title to something more pertinent like CPU temp issue or something along those lines..
I've updated the title to "[solved] high CPU temp due to overclocking?"...how does that sound?
Cheers!
