[Verizon] Titanium and USB Debugging error
darkcyber
Android Expert
I have installed Liquid ROM on my Nexus and running Titanium Pro and when I start it up I get this error:
Warning - System configuration
Your system settings may cause problems. To correct this, go to your phone's Settings, then in "applications" then in "development" and tick the USB Debugging" checkbox.
I have looked under Settings and do not see "applications". I do see "apps", but USB Debug is not under there.
Under "developer options" there is an "android debugging" and I checked that, but still get the error message. So, where is USB Debugging at in Liquid...anyone know?
I'm guessing that its the "regular" USB debugging settings (first entry in the Settings -> Developer options like you already referenced) that we have on our GNexii.
Their app is referencing the old (pre-4.x) way of turning on USB debugging (it was stored under the Applications group in Settings).
If its still saying you don't have it checked and you do indeed do have Settings -> Developer options -> USB debugging checked, then their app just doesn't know how to read that setting in ICS (which should just be a simple getprop call, though).
If so, you could alert Titanium folks or check their web/support site and see if others are also reporting this.
Good luck and cheers!
Thanks Scary Alien! Congrats on Moderator :)
I just tried with android debugging on and off and couldn't replicate the issue. I was able to use Titanium both times if it isn't preventing you from making/restoring backups I would disregard it.
It does not stop me from using it was just trying to fix that error message. I can backup and restore with it.
More than likely I got the error the first time I launched the app but didn't bother reading it. I don't usually read the popups when Titanium loads. Liquids ICS RLS4 turns off USB debuggings on reboot for some reason as well.
