[Verizon] Titanium Backup
tb does not backup sms and mms there are apps for that i believe backup everything is one of them i use backup to gmail because it backs up call log and sms
I believe [SMS/MMS/APN] Dialer Storage is the restore option for sms/mms on a stock phone or a stockish rom. However it's system data so as with any such item, be careful restoring and I don't know that I'd be too apt to do this on many custom roms anyway.
For example, on BAMF, it's listed as:
[SMS/MMS/APN] Phone/Mesaging Storage 4.0.3-eng.chaos.xxxxxxxxxxxxx
So I think that may not play well when restoring across other roms. I don't care about saving sms/mms anyway, but if I were, I think I'd use an alternate method. Cloud service or similar.
SMS to Text Pro version is my ticket. I back up my messages via HTML for easy viewing on the PC and can export them via email.
To back them up per-say, so I can restore them I export them to a file or email them as .txt. Then can import them back in.
Just wondering if it is possible to have tibu batch backup only apps+data that are not system or market apps. I'm asking in here so I don't have to start a whole new thread and it seems on topic enough lol. :)
I'm wondering if this will work with custom roms. My SMS storage is titled differently than stock, because I'm object liquid and the SMS application is customized for the rom. I imagine that it would work when simply updating the Roman, but switching roms...I imagine that would cause a problem. What do you guys think?
You can just restore data and not the apk. That is what I do. I am not sure. I know restoring the app will cause problems for sure. Not sure on just data.
