[Verizon] Touch CWM
Old Member
Android Expert
User Nathan Grebowiec, Twitter name Unstableapps has created a touch version of CWM.
Here is a link the the CDMA version of it.
He stresses that this is an ALPHA build so flash with caution. If you are brave enough to flash, let us know how it goes.
Here is his full post for Google+
Nathan Grebowiec - Yesterday 1:31 PM (edited) - Public
A test version of a Touch Enabled ClockworkMod Recovery for the Galaxy Nexus is now available. Please note this is considered an alpha build, so be kind. You can use both the touch panel and the hardware keys in this release.
For CDMA/LTE Galaxy Nexus:
http://dl.dropbox.com/u/3727513/cwmr_touch_beta4_toro.img
MD5 (cwmr_touch_beta4_toro.img) = 64aef57ea8878bd508dd3c58c86bedb9
For GSM Galaxy Nexus:
http://dl.dropbox.com/u/3727513/cwmr_touch_beta4_maguro.img
MD5 (cwmr_touch_beta4_maguro.img) = b999998be59aeb885907518dd5ba40e6
Updated 1/5 - Fixed the assert issues! Also has the sexy new font by +Chris Ennis
Updated 9:42PM Central - Fixed flashing screen! Alpha 2 is up for both platforms.
Updated 4:00PM Central - Beta 3! With gestures for scrolling and forward and back.
Updated 1/10/2012 - Beta 4! A few tweaks to get ready for porting to other devices. Haptic is a bit weaker now. New Visual feedback on the virtual keys by +Chris Ennis
People involved in this little project:
Me - I made the magical codes
+Chris Ennis - Original concept and graphics as well as a few code tweaks
+Koushik Dutta - Well, CWM is kinda his baby. (This isn't his fault...don't bug him if something in it doesn't work right)
ClockworkMod Recovery Touch Version Alpha 1
ClockworkMod Recovery Touch Version Alpha 1 - YouTube
davelm over at Rootzwiki wrote this. (I were having a hell of a time flashing this until this wonderful individual broke it down).
Like said before, easiest/safest way is to use PC.
  • On your computer, head into your SDK/Tools folder or wherever your adb.exe and fastboot.exe files are.
  • Place the downloaded file there:
I've been using the touch CWM and I've had no issues with it so far. You can still use it like the original version, you also have on screen buttons with haptic feedback or you can use the touch screen to scroll and select. Pretty nice to have all those options if you ask me.
Did you flash the above version as in post one or the second way mentioned?
Im running this as well, works great! the sofkeys are great, touch/swipe gestures work great but make me nervous ill make incorrect selections.
As far as i know the only way to get this is to flash via fastboot, do not attempt to flash this with CWR.
I'm still suing beta 3 and haven't had a single issue with it. I'll be buying the app to show my support, but updating through fastboot as it's incredibly easy
