bevardimus
Hello all,
I have used this method to unroot my phone and put it back on stock 4.0.2:
[HOW TO] Unroot the VZW GN, Re-Lock the bootloader and Start Factory Fresh
I previously had 4.0.4 stock rooted with CWM recovery. The un-root method at that site worked; my phone is unrooted, but I have 2 problems: one major and one minor.
The major problem is that the stock recovery image seems to be corrupt. I can bring up the bootloader, but when I select recovery I am taken to an image of an android with a red triangle with an exclamation point. I have googled this, but all solutions I have found involve flashing CWM. I don't want to, as I want my phone to be 100% stock with stock recovery so I can receive OTA updates without losing root(if they EVER come), and use Google Wallet, and ultimately stop this madness of rooting and re-rooting and just ENJOY my GNex, instead of constantly worrying about its OS. So, can anybody inform me of how to fix my STOCK recovery? Again, I DON'T want CWM.
The minor problem is that I can't seem to update the google+ app since unrooting. Every other one of my 75+ apps downloaded and updated just fine, it's only G+ that failed. It gives me the following message when I try:
'Update for "google+" could not be downloaded due to an error. (941)'
Clearing cache/data and force stopping G+ doesn't solve this, either. This problem is miniscule compared to the recovery issue I'm having, but if anyone has an answer for this as well, I'd be much appreciative.
Thanks in advance!
EDIT:
As can be seen in the below posts, the "dead android" image is actually normal, unless there are specific files present for the stock recovery to interact with. Also, re-flashing recovery "fixed" the google+ issue. Please see Scary Alien's posts for more detail.
Thanks in advance!
EDIT:
