Root Very Confused
NightThorn
Member
Ok sorry guys for starting a new tread, but i am having alot of problems. I want to have the data to sd ext partition, but i want everything else stock. I have tried several ways to do this, but to no avail. If anyone has any help, i would appreciate it.I like CM7 B5 but im looking for everything stock.
http://androidforums.com/galaxy-pre...11392-rom-gb-2-3-6-halfassrom-stock-ext4.html
and
http://androidforums.com/galaxy-prevail-all-things-root/429740-kernel-gb-koumakernel-2-3-a.html
That should give you exactly what you want :)
Enjoy
The Koumakernels do not work with Gingerbread as far as I know so the best way would be the rooted gingerbread with CWM Odin image. Then install Darktremor's App2SD. Follow the instructions in the Readme that comes with App2Sd
Kouma wouldnt be pointing him <her?> toward it if it didnt work...
Thanks everyone. I don't have time this morning to mess with it. But when i get back home, I will play with it then.
