rsmith9113
OK. so here is the scoop. I rooted my droid, was running a custom rom, new kernel, all the good stuff a rooted droid can do. One day on a day, off from work i decided to fool around with ROM manager, to see which roms were cool and if i like them or not. my phone was rooted at 2.1, by the way. so i downloaded a couple roms but didnt really like them, so i downloaded the froyo kangerade v5.0.9 and i seemed to like it. This is where the fun starts. I went into setcpu and it said that i had no root access, non of the kangerade scripts from that said app were working, and i couldn't get the lock screen to work when i tapped the power button. After that i realize i cant receive calls for some reason. It also says that im running 2.2. handcent sms wasnt working right. I tried to boot into recovery (holding down X on the keyboard...) and it wouldn't work. and when i went into settings>privacy>factory data reset.. nothing worked.
i can still make calls, text, google talk, but i cant check my vmail unless it's from another phone. i did some research and i came out with maybe i have to flash the recovery image.. but i dont know what that means.
some other points... every single time i try to reboot into recovery either using kangerade scripts or doing a hard reset it just boots normally. i dont have to slide to unlock, at all. and most of all i think its a serious issue. I know very little about all other things needed to be done which is why i need your help with pretty much a walkthrough on how to fix it. just a solution to get it to factory settings would be great.
THANKS!
THANKS!
