Help Vibrate not working
jkd12589
I searched the threads and the forums and the only fix people have is hard rebooting and sound manager. Neither of which has worked for me. I also did a nandroid restore back to gingerbread and still no vibrations on anything... all my settings are turned on. i hold the volume button down to were it would go to vibrate, but it doesnt vibrate. It only shows vibrate mode.
Also it no longer vibrates when I start the phone.
Things i have tried...
Flashed different roms
superwipe
wipe date/dalvic/cache
nandroid
sound manager
adjust all settings
hard resets
is there anything missing?
or do you guys think the hardware is the issue?
this started a few days ago
sounds like it may be a hardware issue but lets try this
go back to settings and uncheck everything you have selected with vibrate. then recheck them reboot wipe cache/dalvic and reboot and see what happens you should be able to press the volume down key and see if the phone vibrates when you push the key down to vibrate for Ringer Volume.
