hi friends
vibrator of my A70 is not working..........its not physically damaged is anyone facing this problem i tried reseting the phone but issue not resolved![]()
Hey akshay, did this problem occur when you were playing a game which uses phone vibration consistenly?
hi friends
no i am on original rom......i have done everything but now i am feeling that in-spite of good display and good hardware the build quality is very poor...........i am thinking to sell it out if someone willing to buyAre you in ASeventy Rom !
Did you check setting !!
Wipe cache and wipe data from the recovery after taking appropriate backups !
Often the vibrator of a70 gets loosed,so it stops working......
To resolve the problem -
1-Put your phone in vibration mode by holding vol dwn bttn untin silent appears..
2-Make a call frm another no. to ur no on a70...
3-PRESS the area left to earpiece, where light sensor is placed...
4-Try pressing it 3-4 times hardly untill the mobile starts vibrating in the call...
5-Repeat the steps if it again stops vibrating..
This works for me...
If u get it vibrating., hit the Thanks button.....
yes thanks my friend it starts working again but it is loosing very often
ya i wnt to buy it cl me on 9298203776no i am on original rom......i have done everything but now i am feeling that in-spite of good display and good hardware the build quality is very poor...........i am thinking to sell it out if someone willing to buy
Thanx for solution.Often the vibrator of a70 gets loosed,so it stops working......
Hello guys......I faced the same problem from 2nd day i thought it had hardware problems and was like disheartened but my brother ( works in samsung ) held my mobile from bottom end slapped it on the other hand 3-4 times since then my vibrator never stopped![]()
i guess ur bro can make normal people dance like hell jus by slapping themThats funny...but problem is vibrator gets loosen from its socket in phone.i opened the device once n placed it properly with some packings(lol) n never faced the problem again...but ur trick is bit easy,lol..
he he.... ROFL.......
