Vibrator on Phone Dialer
veryjiggy
Hi,
I got my HTC Desire delivered yesterday, but there is a slight problem I have noticed with it. Even after turning all possible vibration options off (i.e. haptic feedback and 'vibrate when you type' in text input), the vibratory mode on the phone dialer still doesn't go away. When I press the keys on the phone dialer keypad, it still vibrates. I have no idea whether it is a HTC feature or a problem with my handset.
Has anyone else noticed this?
My Desire exhibits this behaviour too, even though haptic feedback has been disabled for the QWERTY keyboard. As far as I can see in combing through settings menus there is no way to control whether this is enabled or not.
Thanks, its just that it is terribly irritating if he phone keeps vibrating when you are trying to dial a number. I just wanted to check whether this is standard or something wrong in my handset.
Did you guys have any luck finding out why this happens?
I've got the same behaviour too and its really annoying, Haptic Feedback is disabled but this seems to only apply to keyboard settings and not the phone dialer ...grrr...
Any workarounds?
Menu > Settings > sound and display > "haptic feedback" off
Menu > Settings > sound and display > "Audible touch tones" off
Dialer one is an app, it replaces your normal dialer and is brilliant, I use it myself
Thanks Lekky, I have both of those options disabled, yet I still get the vibrate !!
I'll look at dialer one..
Thanks
