mqureshi79
Member
I have a g tab running tnt-lite. Can I get a flash / external USB drive (fat32 formatted) plugged in to watch movies etc?
Okay, plugged it in, showed up as usbdisk, but when I go in it says "directory is empty"...? Anything else I could do?Needs to be fat 32. I use a Western Digital 500gb. Works great and powers fine using the Gtablet. I prefer using my 64gb thumbdrive, but handy, none the less.
Should show up in ES or Astro (both if you have them).
It will be USB storage in Gtablet parent directory.
