masterdbugger
Don't you guys use the sim card to connect to the 3g/2g networks? On the sprint network we only use it for 4g, so we can still access the CDMA network without it. It's not currently being recognized by the phone
I think that's your issue. If you can get the rom to read the sim card, you should be able to get it to access 3/4g data. Virgin/Sprint needs it to access 4g
And I use them to connect to anything!
Could it be something we missed in the BoardConfig or overlay? Or is it that we're using the wrong blobs?
Changing the app mms.apk in system/priv-app by app mms.apk stock works perfectly incoming and outgoing SMS.
libacdbloader.so
libcordon.so
libcsd-client.so
libdiag.so
libdsi_netctrl.so
libdsutils.so
libfactoryutil.so
libidl.so
libnetmgr.so
libomission_avoidance.so
libqcci_legacy.so
libqdi.so
libqdp.so
libqmi_cci.so
libqmi_client_qmux.so
libqmi_common_so.so
libqmi_csi.so
libqmi_encdec.so
libqmiservices.so
libqmi.so
libQSEEComAPI.so
libril-qc-qmi-1.so
libril-qcril-hook-oem.so
libril.so
libsecnativefeature.so
libsecril-client.so
ds_fmc_appd
netmgrd
qmuxd
qseecomd
rild
sec-ril
LTE data works for me, but calls only work if I do LTE/WCDMA (I used a friend's sim card)Great find. I'll mess with it tonight on vm/sprint end. Does it get 4g?
Not yet, I'll be working on the camera and the vibrator once I nail down the calls issue...Some progress with the camera?
I've also discovered that you can't receive calls... Texts both ways work fine though.
Not being able to receive calls was the issue with the liquid smooth rom. Phenomx4's February 5th rom received phone calls but had a memory leak. His February 8th rom fixed the memory leak but didn't receive calls. Sounds like your making great progress![]()
Damnit, now I have to find more blobs :/
Yeah... I actually tried those before moving to the LS KK ones, I couldn't get them to work, BUT I'll try again now
Yeah, I was just gzipping a random assortment of them now, actually xDMaybe a mix?
I thought you were talking about his stock F6 rom (which has fully working data, and you can hang up calls, but I can't test calling since the phone app crashes on that rom)CANNOT LINK EXECUTABLE: cannot locate symbol "rild" referenced by "rild"...
Diag_LSM_Init: Failed to open handle to diag driver, error = 13
Odd behavior with the graphics drivers? And you installed gapps from the cyanogenmod site, right?Running this rom now, camera doesn't work, but I knew that wouldn't, but. . .odd behavior with the graphics drivers. I downloaded FFVII G Bike from the Japanese play store and installed it, it installs just fine, but when I boot the game it force closes, no error message, just a force close. Thought I'd mention the bug.
Did you see any weird graphical glitches when it crashed?I installed the gapps provided to go with the rom on the site linked. Like I said, the game installed fine, no problems. It just crashed on boot.
