Thanks for the info.
But I think I tried everything to no success. I think my phone is "cursed" with that stupid Virgin Mobile intro.
I have replaced the sound with a custom sound just for testing it... It was fairly easy and took less than a minute. As for the animation, I haven't looked into it... If I can find out about the animation, I will post both in the next post and if I can't find out about the animation, then I will just post how to change or remove the sound.
I'm actually in the process of making a video for this alreadyyou need root and es file explorer with rw set for everything. your looking in system/media/ui or some such for booton or some such.ogg simply rename and take the .ogg away for the sound and the video is samsungor other. same process
system/media/
VMU-bootsamsung.ogg for video
system/media/audio/ui
poweron.ogg
poweroff.ogg
for sounds
I'm actually in the process of making a video for this already![]()
i am just looking to remove as many of the annoying sounds and ani i can.
kill shutter sound for camera thanks to a change in the xml file so i can toggle it.
killed alot in my book. got link2sd working
I got rid of a ton of sounds too! Just got to make the video for the shutter sound. I would be interested in the toggle for the shutter sound though... If you could send that to me somehow that'd be great!
1. browse to system/csc
2. open feature.xml in a text editor. (With root explorer hold down on the file and choose open in text editor.)
3. Under find the following line
false
Change the false to true. Save and exit. Reboot your phone and under camera settings just under GPS Tag you will have the option to turn it on or off.
To get this to work you must also change permissions.
this is all you have to do How to Turn Off Your Shutter Sound In 2 Minutes - Android Forums at AndroidCentral.com first post snipped for easy of answering
Here's the original thread with download links, video, and step by step picture instructions, huge thanks to xessus and djanbech!
