Root [Virgin Mobile] I have royally messed up
OzzyPyro
okay so when i tried to unroot i really messed up somehow, and i deleted external and internal storage, and wiped the system....i currently have NO OS. if i turn the phone on, it goes to the Victorious Rom screen, then sits there indefinetly. i can't get Odin to flash anything to the phone, and under the TWRP menu i tried installing a stock rom or any rom from there, with no luck. i can't do ANYTHING....please help D:
You'll be fine!
  1. Boot into TWRP and make backup of just cache and store it to external sdcard
  2. Download this backup: http://g60madman.vmobi.us/goghvmu/stock/TWRP.zip
  3. Extract the backup, look inside the folders, you want the folder with the date/time stamp for a name
  4. Turn off your phone, take out the sdcard and put it in your computer
  5. Copy the date time stamp to your sdcard's TWRP/BACKUPS/<random-number> folder
  6. Put your sdcard back in your phone
  7. Boot into TWRP and restore the backup you just copied over, don't forget to look in external!
  8. Wipe cache and dalvik cache
  9. Reboot system
oh man, you are a life saver!!! thanks so much :D and i will be looking forward to going to the new victorious once its fully ready. you do some amazing stuff, keep at it!
