Root [Virgin Mobile] I need help :(
Why does the Md5 need edited out of interest? Ive never used someone elses nandroid. Hopefully the VM s3 gets some developer love soon guys :thumbup:
Managed to get the Virgin Mobile recovery up and running. I can't say I have ever been happier to hear that awful Virgin bootup sound.
Now the problem I am having is the phone locks up after a few seconds of boot and restarts itself. Any idea why this might be happening?
Ok, got everything working again. For whatever reason once I got past the initial setup it stopped freezing. Couldn't activate the phone because it had already been activated with that MEID, but a quick call to VM fixed that.
Thank you everybody for the help on this.
If anyone has a backup rom, can you please send me a link to where to download it through private message? I greatly appreciate it if you did.
no, unzip and put into your clockworkmod backup folder
or if you don't have one... make a folder called "clockworkmod" on your SD card then put a folder named "backup" inside that one.... then put the folder in my zip inside
I am running a fully sprint rom an moderm will I need a vm moderm zip to get back stock ?
if you flashed a sprint radio with odin then you may be out of luck till the VM firmware gets released.... You might wanna claim ignorance and try to return your phone if possible....
Backup and Restore (that's tge option you want to open after that just select restore or advance restore depending if you only need a specific file or not
Oki Imma give this a shot now.
Uhhhhhhh It gives as "Error in while trying to restore /system" Right after "Checking MD5 Sum"
weird... I just restored from it.... I'll upload another one in the AM... got off an 18hr shift about three hours ago... need some rest, sorry it didn't like the backup... I'll put up another real soon.
