xclusive36
Android Expert
The 6.0.4.4 cwm also worked for the tmobile f3.Wait...so you're saying it works on your t-mobile f3?
No. It only changes the recovery.It unlock bootloader???
Flash kernel oc V6 of ls720....
Error booting)
Not brick :v
so this might be a noob question, but can you flash this via cwm or only thru 2nd init? was jus trying to prevent the factory reset and re-installation off all my apps
I need more info. What happened when you say it didn't work using Windows installer
It couldn't find SU even though the phone was connected via mtp and seen by the pc.
Figured out my way round it. Reran playgod lte2 exploit. Then booted to cwm. Installed cwmt zip file, rebooted recovery to check. Worked, shut off phone. Used vol down, and pwr. For some reason didn't work, so I shut down phone after booting Android. This time, used vol down, home, and pwr. Got prompt to release buttons, then phone booted cwmt. Whew! Tried that a 2nd time to be sure.
Then rebooted, and came on here thru phone to reply to you. Dunno why I have to use home while booting to get to cwmt now, but if it works solid, then it's all good.![]()
i have dumb question. i have a t-mobile optimus f3 and i saw the one post of the other member have a t-mobile and this working for him. i was going to try it with mine but i cant tell what version i have. you guys are talking about v5 and v6. im looking at my info and i cant seem to figure which one i have. so this is my phone info....can someone let me know which one i have and if i should go ahead and try using this recovery:
model - lg p659 (fx3t)
baseband version - M8930B-AAAATAZM-3.2.25033
android - 4.1.2
kernel architecture - armv7l
kernel version - 3.4.0-perf-gc71fdda (P65910b.1383555226)
Build number - JZO54K
Software version - P65910b
(and yes its rooted already)
Thanks in advance for anyone who helps me out.
Where can I find the 6.0.4.4 version? The OP has 6.0.4.8 listed in the first thread.The 6.0.4.4 cwm also worked for the tmobile f3.
Did you flash the recovery?
btw, v5 and v6 refer to the Virgin Mobile Software update version; LS720ZV5 or LS720ZV6. T-mobile uses their own software update versions. P65910b in your case.
I believe it worked because I am backing up my phone right now through ClockworkMod Recovery, but I saw the following:if you're going to try it and you're successful...please post back and let me know, please. thanks.
What method did you use to enter recovery, key combo or reboot- recovery command?
The key combo
