I downloaded a separate message app... It seems to have corrected that problem with ver 10....i like it though.... Very light and fast
Looks like there is a problem with the repository so for now you will need the supplemental pack for LG.
Which is weird, do they actually install for you? You can launch them from the app drawer?
It's funny because they are the same apk files that I put in the Supplemental pack, which works perfectly.
Overclock was removed in v4 because it is unstable. You can however click the link to the credit i gave for the kernel, and find the overclock V4 kernel in my OPVery nice! I am enjoying it. Two issues though:
1) Google Play indicates that Voice Search is installed, but it is nowhere to be found.
2) You mention that Overclocking and NoFrills are including, but I don't see the app, and when I tried other CPU tuners, I was not able to overclock the CPU.
I just registered on this site (something i never do) to demand you post a paypal donation link so I can send you $25.
I just activated a donated Optimus F3 and this seems to be the only rom available. I activated the phone, installed v10, and my issue (MMS) was fixed when I woke up this morning.
Bravo, sir. You made my new phone run fast and look good without all the virgin mobile garbage on it.
Ill work on the ok google thing, to clear the defaults for the lg home launcher(which i just verified):I think what the last guy was getting at-- or my problem at least, is that voice search is installed but none of the programs can see it - - SwiftKey has a voice function I've been trying to use but it won't recognize that voice search is installed and keeps promping me to install.
Also, I've been trying to find a way to use the OK Google voice thing but I can't find out a way to switch the launcher to Google now. It prompts me to go to apps - home - clear defaults but there's no defaults to clear.
I tried a program called open mic but it disabled my microphone for calls, I assume because it grabs the mic to listen for my voice at all times..
If you could figure out some way where I can say "computer on" like Star trek and have it do the OK Google search I would up my ante from $25 because you would deserve more than $25 for turning this bargain second tier carrier smartphone into a goddamn tricorder
ive used open mic and you can change the hotword but the app does interfere with the audio for some reason. google now is the only launcher where you can use hotword to launch sesrch app without going into the google app. i believe there are some xposed modules where u can change the hotword. i used to use hi android lol but it open mic had to many bugs.
E/ActivityThread( 940): Activity com.google.android.launcher.GEL has leaked IntentReceiver bfx@41fcfb88 that was originally registered here. Are you missing a call to unregisterReceiver()?
E/ActivityThread( 940): android.app.IntentReceiverLeaked: Activity com.google.android.launcher.GEL has leaked IntentReceiver bfx@41fcfb88 that was originally registered here. Are you missing a call to unregisterReceiver()?
E/ActivityThread( 940): at android.app.LoadedApk$ReceiverDispatcher.<init>(LoadedApk.java:792)
E/ActivityThread( 940): at android.app.LoadedApk.getReceiverDispatcher(LoadedApk.java:593)
E/ActivityThread( 940): at android.app.ContextImpl.registerReceiverInternal(ContextImpl.java:1173)
E/ActivityThread( 940): at android.app.ContextImpl.registerReceiver(ContextImpl.java:1160)
E/ActivityThread( 940): at android.content.ContextWrapper.registerReceiver(ContextWrapper.java:372)
E/ActivityThread( 940): at com.google.android.launcher.GEL.onCreate(PG:163)
E/ActivityThread( 940): at android.app.Activity.performCreate(Activity.java:5202)
E/ActivityThread( 940): at android.app.Instrumentation.callActivityOnCreate(Instrumentation.java:1082)
E/ActivityThread( 940): at android.app.ActivityThread.performLaunchActivity(ActivityThread.java:2037)
E/ActivityThread( 940): at android.app.ActivityThread.handleLaunchActivity(ActivityThread.java:2098)
E/ActivityThread( 940): at android.app.ActivityThread.access$600(ActivityThread.java:138)
E/ActivityThread( 940): at android.app.ActivityThread$H.handleMessage(ActivityThread.java:1204)
E/ActivityThread( 940): at android.os.Handler.dispatchMessage(Handler.java:99)
E/ActivityThread( 940): at android.os.Looper.loop(Looper.java:137)
E/ActivityThread( 940): at android.app.ActivityThread.main(ActivityThread.java:4945)
E/ActivityThread( 940): at java.lang.reflect.Method.invokeNative(Native Method)
E/ActivityThread( 940): at java.lang.reflect.Method.invoke(Method.java:511)
E/ActivityThread( 940): at com.android.internal.os.ZygoteInit$MethodAndArgsCaller.run(ZygoteInit.java:794)
E/ActivityThread( 940): at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:561)
E/ActivityThread( 940): at dalvik.system.NativeStart.main(Native Method)
