When viewing the Voice Search app in Play Store (before installing) Play Store reports this as being installed - no 'Open' Button.
Voice Search works fine after installing it (from a apk file on SD Card) until the next boot. Then Voice Search requires a reinstall.
I'm not in a big hurry for v8. I was good with Firmware V6 - until I messed it up and decided might as well try your ROM and move up a step to v7.I do however, plan on making an AdvancedStock8, which will be based on the v8. AdvancedStock7 will be able to update to that version when I release it, but that is going to take some time.
Cool. What was the problem (like to know these things for future reference)?I know what the problem is now. I will fix it in version 15 of the ROM.
Appreciate the quick troubleshooting.
The Google Voice search that was installed in the unmodified Stock ROM for our phone is causing this issue, Here is how updating "built-in apps" work:
What I would do is remove VoiceSearch.apk from the "/system/app" folder and install it from google play and see if that fixes the issue.
Glad it worked!!! Keep me posted on how you like the rom!
The init.d is custom made by me for use with advancedstock rom only. it does not currently have a feature to disable notifications, but will in version 15 of advancedstock.
Yes i will also remove the VoiceSearchStub.apk
Please enjoy the rom!
I am using link2sd and it seems to work. That is why I have 400mb left according to the Internal Storage, yet I cannot install Google Maps..
