pfoneguy
Member
Hello,
I would like to ask a few questions.
What are the basic differences between the Sprint Victory and the VM Victory? I have a Zact Victory which is pretty much just a Sprint Victory with Zact application installed. If you have the MSL you can actually go in a just turn off the Zact/Its On functionality. I have already had the Zact Victory and a Zact SG SIII activated on RingPlus with no issues and Ting cleared the ESN for a SIII I had.
My apprehension is that Zact is now ceasing operations and they are transitioning Zact users to "VM Custom". VM is sending out and OTA update to swap the Zact functionality over to the VM Custom functionality. I would really like to try this service since the first month is free. But..... It always seems to be mentioned that most the workings of the Sprint version are not interchangeable with the VM version, radio different? So, I am concerned that this OTA download may marry my device with VM in some fashion, change the ability for it to function with Sprint if I decide to move it back to a Sprint MVNO?
One reason I want to keep the ability to move this device back to Sprint is that the Zact Victories don't seem to have the in call volume issue like Sprint versions.
So how to CYA? Should I root the phone? Is there a way to make a full system back up that I could reinstall in case VM wants to marry my device to their service? Or back up certain parameters?
Your thoughts would be appreciated.
