eljefe0000 said:you dont know the trouble you have to go thru just to find this jeez
http://androidforums.com/esteem-all-things-root/481810-rom-ld-lg-stock-debloated-zvd-c-b.html
bcifer said:Hello ldrifta,
First, I want to thank you for your work and help.
Do you have a copy of a "Virgin ZVD" with only the MetroPCS bloatware removed.
-Thank You.
Got what I needed. you guys are so helpful. thanks...
you know the thanks button is there for a reason not for show
Yes, thanks. You guys are the best...
I looked before I hit the "new thread" but didn't really find it, unless I'm not looking correctly.
What I was looking for is a back up right after the update to ZVD.
Fuzzy13 I did look in there but did not find what i was looking for...
I was looking for a stock/UNbloated ZVD. ldrifta had one sometime ago that it was just UNbloated nothing else was touched.
Thanks.
LD-LG ZVD 2.6 is not stock. Really looking get rid-off all the odex from /system/app. I have a stock now but it has all that.
thanks
No I was being sarcastic because he was giving me a lesson on the thank button.
Ah. Makes sense now. I assumed that's what you wanted.
Stock system pulls are exactly what it says though. Stock.
hey man you get what you ask for you wanted debloated stock rom and thats what i linked you up to you have to be more specific for what your lookin for cause a lot of people ask for stuff thats already here besides im just bustin your balls a little i apologize if you felt offended
bcifer said:LOL, not at all we grown man in here its all good. I tough that I was being specific when i wrote "Virgin ZVD" with only the MetroPCS bloatware removed"... anyways is it possible to remove all the odex from a stock back up?
-Thank You![]()
eljefe0000 said:heres what i would do. a backup and then boot into stock debloated from there you can use root explorer or what ever you use and go into system/app and remove what you want apk's. and odex files im sure you would need somethings for the rom to function so you just cant delete everything. then reboot and see if its functional and i do remember that other rom your talkin about it was just a rooted stock rom i believe with the bloatware i think not sure though
