Purpleclad
Any idea if the note has visual voicemail on it like the Skyrocket does? Thanks in advance.
Talked to ATT and Samsung, and there is no visual voicemail on Note like Skyrocket.
It is posted on xda that to access it you have to go to the voicemail settings and change it from my carrier to visual
They also have the apk posted there
Worked for me. Saw the link on the internet last night and didn't get a chance to do it until today, worked fine for me. I had the Skyrocket right before this, so maybe that helped since it has Visual Voicemail. Hope it works for everyone else!!!That last link SHOULD work, but it wont authenticate on mine. I'm going to Call AT&T tomorrow and make sure visual voicemail option is tied to my number.
Hi guys, first post. This is my first Adroid device so I'm new to this OS.
iOS user for the last 4 years. I'm looking for some guidance (help). I really want visual voicemail to work on my note. Would some one be kind enought to give me instructions on where to start.
Do I download the link with my pc or the Galaxy note? Than how do I install it?
If some one could help, I will be forever grateful.
Thanks in advance.
Will
Thanks in advance.
Will
Thanks in advance.
Will
Glad I could help. These forums are great. My thanks to all the tips and the app that was posted. Thank you everyone!Richcop, you are the man. Many many thanks, works like a charm. Not quite like what I have on the iPhone, but close enough!
Thanks again.
Will
Ok, I just did all this and it works great as long as you didnt use AT&T Messages program first (if you did they will need to remove your VM and or data pack and re-add). So here are the steps.
1. Download and install ES File Explorer if you dont already have it.
2. Download the file they posted for the Visual Voicemail and install it under the downloads with your ES File Explorer. It should work right away unless as I said that you started using the AT&T Messages app. They will have to remove that because it uses the old school voicemail to work. Good Luck!
I use Google Voice on my Inspire. We can't use it on the Note???
