Space Cowboy
Member
I loved being able to press a button on my WM6 phone and telling it do dial a number or other commands. Is there anything similar to this for the capitvate?
Thanks!
Thanks!
Read the forums dude! This has been covered extensively! In short - the Google search bar has a microphone on it. Hit it and tell it what you want to do - "Call Bill at work", "Call Sally at home". In a text message, switch your keyboard to Android Keyboard and the mic icon is there as well. Hit it and say what you want to text.
Don't expect the voice dial to be as elegant as MSVC was on your WinMO device. When we get this capability:
- Read back confirmation, so you can say yes or no, and not have it dial wrong number
- Press the talk button on your Bluetooth headset for it to beep and then you speak the command to it
Then it will be great. I see that pretty much as a must if you want true hands-free calling, for example when driving.
I have Vlingo on mine, and I'm not sure it was needed. I can also say "Open <program>", but I don't know if that is because I have Vlingo or if it would do that with stock Android voice control.
The other features of MSVC such as "Play Jazz" for it to call up the music player and play your jazz list, I am expecting to not be on the Android device either, although I haven't tried it yet to see.
New to this phone and android as well, so maybe dumb question, but while I see the mic on the google search, I do not see a mic when I have the keyboard up to type a text message (or email). Is there an app you need to DL?
You can also change it in Settings - Locale and text - Set default keyboardpress and hold on the text area and you should be able to change to the android keyboard... mic button is located in bottom left corner
... This has been covered extensively! In short - the Google search bar has a microphone on it. Hit it and tell it what you want to do - ....
What has also been covered and reported by several people is that what this does is provide an online Google search, not search the address book.
I don't get it?Yes, if you hold down the search button in the lower right hand corner of the device, voice search will come up and all you have to do is say "call first name last name and whether it's a mobile, home, or etc." Not sure if it is able to do any other commands though. It works perfect on mine for voice dialing.
I don't get it?
I've tried this with numerous voice call commands and all I get is a google search on the web.
I have the same problem, even with google synced contacts. If I say, Call Bill, it does a google search for "call bill".
Here is the official word on this from Samsungs level 3 support.
Does My SGH-i897 (Captivate) Phone Support Voice Dialing?=
I am new and happy to see this. can you post a link to that thread? search but couldn't find it
This discussion...
