Root Voice to text not working
ashade07
Just traded phones with the wifey. She is now using my rooted EVO. I did a hard reset to wipe my data, now everything seems to be working fine except the voice to text button on the keyboard... any suggestions? She does not want to start back over, now that the phone is set up.
Any help would be appreciated!
-Aaron
Awesome, thanks... I'm running nitrous rom, everything worked until the phone # swap. Will try your method tomorrow.
Try downloading the google voice search, but that didn't fix it, will try wiping the the delvic cache and cache tonight.
Sorry that didn't seem to fix your problem. I had rooted a phone for a friend of mine and put Decks on it as the first rom and I had the same issue. The remedy for me was the Google voice search, but I'll add that I had to go back and reselect the keyboard in settings so you might take a look at that too.
