Root Voicemail and Camera Woes
longshot
I am running Synergy and I have 2 issues only that seem to happen no matter if I wipe everything 3 to 4 times and reload. Sprint Voicmail will not work correctly. When someone calls it sends me an SMS message that I have a voicemail and to dial a number that wont work. I call my own number to check the voicemail and it works. The other issue is the camera. Can take 3 pics and the phone reboots.
I haven't heard this issue for the camera for a loooong time. It may be a fluke but if you did a wipe of cache and Dalvik cache and that didn't solve the problem then a full wipe could be in order. Which Synergy rom are you on?
As far as the voicemail is concerned, I would highly, highly recommend moving forward and use Google Voice as your voicemail. I've been using GV since 1/10 and never have had an issue. Plus it's too darn easy to set up voicemail when flashing roms.
Download GV from the market
Sign in
Voicemail is set up
There are a few things with the initial setup for GV but after that, smooth sailing;)
