Root voicemail?
fullbloodedmut
i received a voicemail from metro stating i need to bring my esteem in for a important update,or they say my fone will not receive the new speeds,is this the new zve update ? or wat,is it because im on #2 2.5 rom and they cant ota the update to my fone,has anyone else received this voicemail too? sorry if someone has already asked,i didnt see anything bout it :confused:
quick question,i was wanting to clean up my fone by reintalling 2.5 and startn fresh,is there a chance wen i do could it trigger my fone to do a ota ???
well im all stock,out of the box,give it alil time to see if update comes on its on,prob jus going to jump to the update tool and see so i can try out ldrifta newbie
Just plug to lg tool and see if it is .i can say something about this ZVE update and it is this file called lte images . Sounds funny but if you delete this the 4g lte will disappears from status bar and phone laggs but when u put this folder back in the 4g lte comes back . Sounds funny but is it some simple files that gives us data . And this update is to stop this TEST MODE i was told . Waiting to see if this is so but just to say check it out for yourself. :eek::D:rolleyes: its called LTE IMAGES what is the pbc bin and where is it located .
Any increasr in speed?
Yes a lot and not the only one that can say i see this .but those speed kernels that was for zvd. That all is dead
