I use an app called Profile, it lets you build different profiles that include settings for sound volumes, notifications, ringtones, connectivity etcetera. Includes widgets that let you switch between the profiles with a single press. I can't live without it, I use a profile for daytime, silent, and night and it works great.
It also supports scheduling profile switching if you want to do that.
Thanks. Is it the one that's $1.99 in the play store? Or can you tell me the Dev. There are so many profile apps.
