atljatl
Ok guys, my volume rocker is not working. I replaced my power button because it had recesed too far to function anymore, and after i reassembled the phone, my volume rocker had stopped working. So, i disassembled the phone (have done so a few times now) and adjusted the rocker, but it seems the rocker connectors are not touching the motherboard contact points correctly. I can press it up and down but nothing happens. As you know, the rocker normally makes a "click" sound when you press it, but now there is no clcking sound. I'm hoping it's just a simple thing of matching the rocker points up with the motherboard and not some other more complicated issue that arose from me prying around inside the phone.
I've searched hi and low for a solution to this but have not found a specific answer. Just wondering if y'all had any ideas/experience with this. I'm thinking about taking some super-glue or melting a thin piece of plastic to the rocker in the hopes of making it contact correctly.. wanted to get some advice here before i go this route.
Frankly, I could get by without a volume rocker for a little while, though it is annoying, but I have an issue with needing to flash roms constantly...so...i'm sure you understand.
:ditto:
:ditto:
