Root vv3 help
jlede
Android Expert
If anyone has vv3 rooted with cwm install can y'all make a stock back up so if you have apps installed make a back up factory reset in cwm the boot into into the phone then make another backup this one should be stock just restore your first back up data file
This is for ldrifta
This is for ldrifta
I would, if only I had a Connect....waiting for them to be sold dirt cheap :p
But I may have increased their prices since finding VV3/4.....
I messed with a Connect running ZV9...it wasn't that bad except she said her battery will only last 30 minutes with heavy use........
Back on topic: I'm sure spec2....(insert rest of name) can do it.
Btw, I'll be around this forum more from now on and try to fix up the ATR thread for ya'll :) PM me if you got some links that need to be added/removed from it.
Is this for the VV3 baseband? If anybody is running VV3 rooted, use terminal to pull it:
Code:
su
dd if=/dev/block/mmcblk0p14 of=/sdcard/baseband.img bs=4096
That *should* dump a copy the baseband.img file that ldrifta might be able to use, in the root of your sd card. It can be sent through email if you compress it.
I'm not running VV3 anymore, since it killed off my GMaps and TTS, otherwise I'd do it :(
