Shatterproof
The very first thing you should always do before anything is make a backup before flashing this and please know that I AM NOT RESPONSIBLE if anything goes wrong or happens to your phone after you use this so please only use this knowing that you do so at your own risk... Ok now that thats out of the way
(vv5 backup rom)
Download this ---> (vv5.zip)
Once its downloaded extract the vv5 folder from the .zip and then place it on your SD card here --> clockworkmod/backup/ once you have done this then you will need to put your phone into Recovery Mode (CWM) once you are there go to -backup and restore- then -restore- then -vv5- run the restore and once its completed then select the option to reboot your phone, after the phone has fully booted you should reboot/restart your phone one more time before using it.
(vv5 baseband/firmware)
Down this ---> (Dropbox Link) Mirror ---> (Mediafire)
Once downloaded place on your phones sdcard, put your phone into recovery mode (CWM) select install from sdcard then navigate to where you placed this downoad and select install then reboot and enjoy
Oh yeah and dont forget to read my sig
(vv5 backup rom)
