Root Waiting for Device
While the dos is stating " waiting for device " go to apps/development and select debugging.
Thank you for posting this - this is the gem people across the net are scumming for.
I did select debugging, but somehow when I followed your advice, it was off. Selecting it on and about 10 seconds later the issue was fixed.
welcome to the forums!!!!!!!!!!!!!!!
glad it worked for you. now go and get your flash on:D:D:D
make sure you install the latest driver for the phone, I did that then it recognised my device.
welcome to AF!!!!!
with htc the only drivers needed is for the ones that comes with htc sync. so long as htc sync is installed or at least the driver for it then you should be fine.
i registerd on this forum just to say why people got this problem
problem is in driver (if it automaticly install it install wrong driver)
here is solution
Instructions to installing HTC Drivers on Windows8 64Bit:
1. Download the Windows7 (64 Bit) drivers here - hxxp://d-h.st/23V (replace xx with tt in link)
2. Unzip to any location you want. Just remember where you put them.
3. Plug in your phone to your USB cable.
4. Open your Device Manager (Windows Key + X and select Device manager) and locate HTC under Other Devices and right click on it and select Update Driver Software
5. Select "Browse my computer for driver software"
6. Click Browse and then select the folder you unzipped with the drivers in it then click next.
7. It should now install your drivers and then in your device manager it will now show up "My HTC" under Android USB Devi
p.s. sorry on my bad english
