Anyone have any luck with getting unlock via trackpad to work? I made a post over at XDA documenting my efforts.
Wakup via Optical Trackpad - xda-developers
it works but not always responsive, sometimes you have to hold the track pad down for awhile
No. It just maps the dpad key to wake the phone. The exact mod is:
key 272 DPAD_CENTER WAKE
Added to the file.
My theory is that it takes a short press when the phone is still awake, but the screen is off. It takes a longer press and hold at other times because the phone must respond to the wake up and ramp up from 250mhz. Or is it 245? I forget what the bottom idle frequency is for the DI.
This takes microseconds, if that.
Probably a low level software thing that just needs to get worked out. Its a known "issue" with all the wakeup apps.
A hardware interrupt will be instant. Well, sorry, at 125MHz it might take 8 nanoseconds.
Again, its software.
its a combination. Its been proven before on the Moto Droid.
