Root wanting to go aosp...
Are there any aosp roms with everything 100%? Want it to have working gps, 4g, wifi and hotspot, a2sd, etc.
yes and no with some of them. aosp does take some tweeking.
1.gps fix for cm7
2.4g should work with most of them
3.wifi should work with most aosp roms
4.sprint hotspot is a no go but cm7 has a tethering app built in.
5.i do not think that a2sd is built in with these roms. check the changelogs. some may have support for darktremors.
I'd go with CM7 (and did). It's a great rom. 4g works, wifi works, tether works (usb/wifi).... everything works. Everything that I've tried at least.
Other alternatives to cm7 are decks and omgb. All have stable builds. They also have newer rest builds too. But cm7 is probably the best of the bunch if you go with their stable 7.0.3.1 build.
