Help warp is really messing up
I have had this phone for about a year and one day it just started really acting up. It seems the back button is being pushed on its own. It vibrates as if it were being pushed and the screen slides on its own. If i own an app, it goes right back out of it. I am not touching it or anything. I already wiped the phone to default settings and it is still doing it. Someone please help.
Well one way to see if it can be fixed is try to root it and see if that helps get all the bloatware apps out of there that could be whats causing your issues.
This could also be a kernel issue. You can root the phone, and flash a OC kernel, All while still staying stock. Your phone will not look any different, just act a whole lot better.
Root the phone using this method. Read the thread thouroughly!!
http://androidforums.com/boost-mobi...ot-method-works-w-b10-update-1-28-2013-a.html
Flash a kernel of your choice using CWM Or TWRP depending on witch recovery you install with the root kit.
http://androidforums.com/boost-mobi...-kernel-glitch-kernel-2-6-35-7-oc-1-8ghz.html
http://androidforums.com/boost-mobi...enwarp-v1-0-4-update-released-11-18-12-a.html
  • Like
Reactions: Doc
