Help Warp on Sprint?
I have a ZTE Warp, but I wanted to use it for my plan on Sprint, that I have now, i am using a blackberry, is there anyway to do this, with DFS or QXDM, would I need a donor phone, or is it just as simple as changing the numbers for the my number with sprint? Thanks in advance
I'm not sure if this is the best place to find a way to do that. Since I haven't met anyone on the warp forum that wasn't still with boost. I would do research on YouTube. . Even if it's not the same phones, it's still the same or similar process. .search boost to sprint and see what you come up with. Research is key. And videos don't lie
yeah, i have been doing research but every time i type in boost to sprint it just gives me sprint to boost instead because of the keywords and all. The only thing close I seen to it, is putting a phone back on sprint that was already designed for sprint, but other than that no such luck. I decided to come here since i found how to get the msl code and use DFS to change the PRL, but i'll continue to look and see if i can find anything.
