i want to repost this as i was about to but read the thread to see if anyone posted about it..
scotch tape... the glue/adhesive in it.. has water in it.. albeit tiny amounts. if you move the phone from hot to cool situations quickly, overtime this will cause wear on the adhesive. the heat from the phone itself will cause issues with the tape.. discoloring it in the process... again over time... the tape will seal the sticker but will also seal in moisture thats in the ROOM you are in when you APPLY the tape! its best to just be careful with the phone. HTC knew what they were doing when they put the sticker there... they have ben producing phones for many many years...
The tape is a good thought but water & water vapor is notorious .... it will either seep under the tape (tape gets loose if it gets damp) or the humidity from the droplets of water will cause it to change anyway due to condensation. The piece of paper could also retain the dampness and the whole thing might backfire on you if you are in a high humidity location.
That is an awful spot for that indicator. Keep it away from the bathroom when you shower.
