Have you tried running in Safe Mode (disabling all apps you added without uninstalling them)? If the problems stop they are caused by an app(s) that you added.
Battery saver apps are notorious performance killers. They kill an app that is auto restarted and they kill the app that is then auto restarted and ... . This just goes on constantly.
Clearing the Data Cache Buffer (where temporary files are stored) periodiclly7 (like once a week) can help.
... Thom
How do you clear the data cache buffer?
My phone is seriously laggy at the moment.
From vzw website ...
Performing a wipe cache partition removes any temporary files that may be causing an issue with the device. All personal files and settings are not affected by this option.
- Power the device off.
Press the Power button then select Power off.![]()
If the device doesn't respond to input, press and hold the Volume Up/Down then press and hold Power button. When the device screen goes blank, release the Power button while continuing to hold Volume Up/Down then proceed with step 3.![]()
- Press and hold the Volume Up/Down then press the Power button.
- When presented with the Boot Mode Selection Menu, release all buttons.
- Press Volume Down to select Recovery then press Volume Up.
- From the Droid triage screen:
- Press and hold Volume down.
- Press and release Volume up.
- Release Volume down.
- Select wipe cache partition then press the Power button.
Use Volume keys to navigate options.![]()
- Select reboot system now then press the Power button.
... Thom
