Help Weather help
The weather app that comes preinstalled on my Casio Gz'one Commando only shows weather for New York and I live in California. How do I change it to my town?
Is your gps on? Might help. I'm using the weather channel weather app(free)if you want to check it out. Works well.
Load My Cast (free). Best weather app IMHO.
I've seen that weather thing that is set to NY and I can't get it to change either no matter what I do (Droid X here). Tried GPS, zip code, name of town/city. Probably Bing crap.
Yea, I had that problem and fixed it yesterday. Make sure that the GPS is on then "double click" to open it up to update. Make sure you are outside or on a porch, it will update to your location.
