weather settings help!!
vx41uk
Hi one an all wonder if anyone can help... when i scroll through screens to my weather page i have current location on there how do i apply it to my home screen under the large flippin clock ?
It should already display your default location under the clock? What location is it displaying atm?
my current location but no weather found it also never changes even after updating no mattter where i travel too cheers :D
Try deleting the clock widget and reapplying it. Select 'Current location' after you add the widget again.
I've had this problem, too, and re-applying the widget (set to current location) doesn't fix it for me. What you need to do is manually specify your location at the point of re-applying the widget, rather than relying on google to pick up your current location - this should work.
Ill try that could u tell me how to set that up kinda confusin me this phone how do i set my current location ?? thx
My location doesnt show when you search for it, but follow to the website and it is there.
So I've had to select the main town in the county to get any weather.
1. Get rid of the existing clock by holding down on it, and then dragging it over the Remove button.
2. Press down on the free space on the screen, and then the Add menu will appear.
3. Select Widget > Clock (HTC)
4. Scroll right to get to the flip-clock and select it.
5. The 'Select a City' menu appears.
6. Do not select Current location
7. Press Add City, and then type in your location.
8. Once you'd done this, you'll be returned to the 'Select a City' menu, but this time your city will appear in the list.
9. Select it and then you're done.
Hope this helps. :)
On my home screen my home location shows up on the display but no weather animation next to it.
Anybody know why this maybe?
Any info would be appreciated.
That happened to me. I fiddled with it for ages and now it works... not sure why... I think I had to change my notification settings under Settings.
The BBC website provides weather for any UK location. Perhaps someone could create a widget which based current location weather information of the BBC data?
The HTC widget will only show weather for locations that are listed when you use the 'add' button.
So I manually set mine, as nothing near me is listed.
