Help Web browsing with gingerbread
Double P
I think I'm missing a setting since the update to GB. It used to be that when browsing the net and zooming in, the page would automatically resize itself to fit the screen. Now it doesn't do that. Anyone know where the setting is to change that?
I've found that if you pinch-to-zoom and then tilt the phone to landscape and then back to portrait it will have resized the text to where you zoomed in. Hope they fix this glitch because I use pinch-to-zoom a lot on the browser. Also does the Android keyboard seem smaller than before? I also have the navigation problem where it locks up my phone when I try to use it. Have any of you tried to do a factory reset and re-download the update to see if it fixes any issues?
noticed my Samsung Fascinate upgraded today and the new version is 2.3.5 which I believe is Gingerbread. The pinch to zoom is no longer working and after searching the web the only solution I have seen is to tap the zoom in at the lower right on the screen. IS there a fix for this or can I roll back to the previous version where things worked?:mad:
