SUroot
Extreme Android User
I was about to flash GV 1.3
I modified a script to delete .apk's. I know it worked before (all be it on froyo). I also added another script I wanted pushing to /system/etc/init.d
Heres the script.
So I flashed GV
Flashed the zip above. Lots of files deleted (good)
Flashed my kernel.
It said done, so time to patch boot. The CWM menu flashed up and disappeared as if I had accidentally chosen something (maybe apply update.zip as that was what it defaulted back to), then said could not find files and gave a misc error.
I mounted USB storage. The entire FAT32 partition was gone. Empty.
I copied files back just to repeat steps. Same happened again.
I did it again without the zip. So just flashed 1.3 and patched boot. file Remained on SD card.
Booted up, looks like my /data is wiped too. No personal data whatsoever. Came up with the set up wizard. GRRRRRRRRRRRRR
But all my apps are there. Everything that was on sd-ext is fine, but they have all lost their settings. I dont get it. What gives?
Flashed back to 1.2 just incase but same problem.
So now I have no data, no settings, NO BACKUPS, everything gone!
Heres the script.
Code:
show_progress 0.1 0
delete SYSTEM:app/Calculator.apk
delete SYSTEM:app/CarHomeGoogle.apk
delete SYSTEM:app/com.keramidas.TitaniumBackup-2.apk
delete SYSTEM:app/DSPManager.apk
delete SYSTEM:app/Email.apk
delete SYSTEM:app/FM.apk
delete SYSTEM:app/GenieWidget.apk
delete SYSTEM:app/Gmail.apk
delete SYSTEM:app/GoogleQuickSearchBox.apk
delete SYSTEM:app/googlevoice.apk
delete SYSTEM:app/LatinIME.apk
delete SYSTEM:app/Launcher2.apk
delete SYSTEM:app/LiveWallpapers.apk
delete SYSTEM:app/LiveWallpapersPicker.apk
delete SYSTEM:app/MagicSmokeWallpapers.apk
delete SYSTEM:app/Maps.apk
delete SYSTEM:app/Music.apk
delete SYSTEM:app/RomManager.apk
delete SYSTEM:app/VoiceDialer.apk
delete SYSTEM:app/VpnServices.apk
delete SYSTEM:app/YouTube.apk
copy_dir PACKAGE:system SYSTEM:
show_progress 0.2 50
set_perm_recursive 0 0 0755 0644 SYSTEM:etc/init.d
show_progress 0.3 100
So I flashed GV
Flashed my kernel.
