Murf1
I have the Virgin Mobile version of the phone.
At home sometimes I turn on the WIFI and it will connect with 1 bar (the dot at the bottom) and it works for about 5 seconds then disconnects. When I try to reconnect it will say "failed to connect" even if I am setting right next to the router and it shows "Excellent" strength on the screen where I tell it to connect.
I rebooted the router and it did not help. I reboot my phone and it connects fine with full bars. I can connect fine and then turn off WIFI on phone and try to connect again 5 hours or more later and get this issue. I reboot the phone and it fixes the issue. Also try the "Clear RAM" button that doesn't fix it. It gets to be a hassle to reboot the phone all the time.
Don't know if it matters, but I always turn on WIFI, use it, and turn it off when I'm done using it for awhile (on the phone).
Anyone know what would cause this or an app that may reset it without having to reboot the phone?
Thanks.
Thanks.
